NorthernIllinois
- Feb 1, 2005
Dealer told me that the watercraft setup will be what is in the 2006 RX1,
2005 Yamaha FX High Output Specifications, minus the water related stuff!
Compare specifications with another model
MSRP
$9,999* Available from October 2004
Rated Horsepower
160 hp @ 10,000 RPM
Engine Type
4-Stroke, In-line, 4-Cylinder, 20 Valve
Bore/Stroke
76 x 58mm
Displacement
1052cc
Fuel
Regular Unleaded
Type of Intake
Spec Not Available
Type of Scavenging
Spec Not Available
Type of Exhaust
Wet
Type of Lubrication
Dry Sump
Mixing Ratio
Not Applicable
Cooling
Open-Looped, Water
Starting
Electric
Ignition
Direct Ignition
Compression Ratio
11.9:1
Carburetor/Injection
EFI (Electric Fuel Injection)
MSRP
Rated Horsepower
160 hp @ 10,000 RPM
Engine Type
Bore/Stroke
76 x 58mm
Displacement
1052cc
Fuel
Regular Unleaded
Type of Intake
Spec Not Available
Type of Scavenging
Spec Not Available
Type of Exhaust
Wet
Type of Lubrication
Dry Sump
Mixing Ratio
Not Applicable
Cooling
Open-Looped, Water
Starting
Electric
Ignition
Direct Ignition
Compression Ratio
11.9:1
