at least two leaking. is this a gasket issue likely? if so where do i get them?
Partzilla.com has them if they are leaking.
Shaggyzr2 let me know it all worked out? Trying to send you a PM but says it is full!!!
shaggyzr2
Inbox is cleaned out. Your gaskets and seals will ship tomorrow. thank you
If you want to put an end to the leaking powervalve towers use a light coat of copper silicon on each side of the gasket so it seals up the parts.If your replacing stuff you should check the seals in the towers that go around the stem of the valve,the o rings in the end caps plus the gaskets between the end caps and towers.
