Avenger III?
underwood
Fargo, ND
My racepack stays on for about a minute and then all screens flash off and it shuts down. Please help.
check your batteries and if not the wires that connect to the coil or power hook up may be tha probelm....
Red wire needs to have power on it when running, check the inline fuse. Sounds like your tach (yellow wire) is getting a signal, but you have no power on the red wire. Also check the ground.
Automatic shut off
What about the automatic shut off in the program fields. You can program how many minutes you want it to stay on if no buttons are pushed. I think it can be as short as one minute and as long as 30 minutes. Where is yours set?
Madmatt
If your talking about the light going off after 1 min, just hold the button in the middle, on the left side in for about 5 sec. This will keep the backlight. At night it seems like the unit turns off but the backlight is just turnning off.
