Plug Heat Range Change
ALLFUN112
Oronoco,Mn
In my project,,I am wondering if I should change heat range of plugs,,due to running this motor at 50-90 degree outside temps,,,thanks in advance for comments!!! Just running the BR9ES plugs,,should I change to something else??
Having alittle trouble there,,,mains jets are ok I believe,,,but the motor will only run correctly at half choke,,,running 45 pilots ,,w, 1 1/2 turn out,,,ordered 47.5's but might just have a blockage in pilot circuit on one of the carbs,,time to do a re-clean
