Viper engine oil line hold downs ??
Vector88
Labrador, CANADA
I have 3 hold down clips that go on with the crankcase bolts. I know where 1 goes for the starter wire but the other 2 are for the oil line. Does anyone know where they go? I took the engine apart a couple months ago and can't quite remember but I'm sure I will figure it out when I get it in the sled but will have to remove it to install the clamps . Anyone got a engine or bottom end laying around that they can send me a picture of with the gold downs in place? Thanks
Thank you Super1c. Very helpful. I had a clamp on one of my longer crankcase bolts but wasn't sure where that one goes. I noticed the other one you have is on the line that supplies the fuel pump from the oil pump. I thought there were 2 clamps on the oil supply line but I could be wrong . Do you see a clamp on the longer crankcase bolts? The one to the starter side of the oil pump is on the shorter crankcase bolt which I got now thanks to your pics.
