what wire is the tach wire on the srx 600
owen i would have to check my manual to tell ya for sure, but i will add if you need another tach, the 00-01-02 tachs won,t work in the 98-99. 3:16x (yammie tony)
its in the hotter ignition. way to much voltage will over power the tach. also the wiring is different. see its a catch 22. the wiring is different mating a 00-01-02 tach on a 98-99, and the 98-99 tach will be overpowered on the 00-01-02. have to use correct years 3:16x (yammie tony)
