SRXPsycho
Hoping someone can help with this issue. I have a 1999 SRX 700. Last year I had an issue of my sled loading up after a trail ride. Would only run on 2 cylinders. When I opened it up full throttle down a stretch of road it would clear up. Sometimes it took a couple pulls of doing this but it would always clear up until I ran the trails again. Any insight to this problem would be very appreciated.
shaggyzr2
clean the carbs!
roudyroy1
go through carbs, almost sounds like the pilot fell out if its loading up
A couple of bucks
SRXPsycho
Thanks for the input guys. I have pulled the carbs and everything clean. I forgot to mention that it has some cutch work don to it. Secondary is marked as follows:
47 degrees Helix
70 degrees Twist
Pink Spring
I am running a Bender Can with Stock pipes.
Main Jets are #1 and 2 146.3 and #3 is 148.8
Not sure what Pilot jet is as there is no number on it. (HOW DO I IDENTIFY THE SIZE?)
Should I rejet?
47 degrees Helix
70 degrees Twist
Pink Spring
Should I rejet?
A couple of bucks
What temperature are you riding in?
SRXPsycho
Average temp is between -5°C to -15°C. Odd time -20°C.
A couple of bucks
Describe the plugs w/ burnback.
bluewho
Sounds like a plug fowling probably from a bad cap,a common problem with 98/99s replace all 3 with the newer style and new plugs and it should be good to go.
YAMMIEGOD3:16
yes on what bluewho posted. go deeper in carbs. pull needle and seats, check screens and o-rings. 3:16x (yammie tony)
A couple of bucks
http://www.totallyamaha.net/forums/threads/75436-Change-your-sparkplug-caps?highlight=Tb05emaSounds like a plug fowling probably from a bad cap,a common problem with 98/99s replace all 3 with the newer style and new plugs and it should be good to go.
