Viper 700 clutching ?
madzx2
Osceola Wi
I just picked up an 02 viper with hauck/cpr pipes. I was going through the clutching and it has X weights with an Allen in the middle hole that weight 50 grams total, a orange primary spring, 8bv50 helix and I think a black/ white secondary spring. Is this a typical clutch setup for the hauck pipes? I won't be able to test it for a while because it needs a crank, cylinder, and piston. Thanks
My kit came with 8dn10s, not sure on weight can check if needed with a Hauck orange primary with there v helix(51-45) green at 60. I've been using heavy hitters lately seem better
the hauck x are fully adjustable and something i would say last owner bought. thats a yamaha helix. this sounds like a good sled. 3:16x (yammie tony)
