Does anyone have the actual code from Yamaha for the blue pearl on the SRXs? Or perhaps the Sherwin Williams paint code for that colour? My local auto parts store started selling S/W paint and if I can get even their code then I can get it mixed locally.
Sent from my XT1058 using Tapatalk
yamaha Blue Pearl, ...this is an official Yamaha color on PPG color charts, although you can take the following recipe to any auto paint supply outlet. By: srx_eh
PPG MIX @1/2 PINT:
DMD624 58.2
DMD675 100.7
PRL92 123.9
PRL90 132.7
DBX1689 267.3
PPG MIX @1/2 PINT:
DMD624 58.2
DMD675 100.7
PRL92 123.9
PRL90 132.7
DBX1689 267.3
shaggyzr2
I've had that PPG code for a few years now and the same auto parts store used to deal with PPG paint,but the mix code is for solvent based paint and they couldn't mix it for the water based stuff or the low VOC according to the counter guy. If I can get the actual paint code used by Yamaha,he tells me he can cross it to a Sherwin Williams paint no problem.
drew24
I had some mixed up a couple years ago. This place also used to deal with ppg and they crossed it and it was a perfect match. The only thing was the price was the same as what it would have cost to get the actual paint Yamaha uses which I think is color-rite. They said it gets expensive when you get into the pearl stuff. Not sure if that helps.
I'll take the mix code over to them and see if it helps at all.
marty f
I bought paint for my 2000 srx trailing arms from amazon,turned out perfect came with aerosol paint and clearcoat!!after clear coat just run a buffing wheel over to bring out the shine..perfect color match..i will look for the link and post
marty f
Yamaha Motorcycle Aerosol Spray Paint 0564 Deep Purplish Blue Metallic C (DPBMC) (TEAM BLUE) is what I bought off amazon!!!!perfect match(COLOR RITE)
