Buying a frame on Ebay from USA?
low slung
Newfoundland
Just wondering if i purchased a used atv/snowmobile frame off Ebay is there any trouble getting it across the border(Due to the VIN and a Title).Is there anything i should be careful of.Thanks.
as long as you re-stamp it with your origonal vin # and remove the one it had, you should be ok. highway trucks follow the same rules when you replace a cab on them.
Many thanks but i think my brother(7skulls) is going to get a new frame at the dealer(Seems his 2012 YFZ450carb developed two massive cracks:o| in the left tube of the main frame by the rear shock).Feel much safer with a new frame than a used one(good knows what its been through).Seems to be a weak point on YFZ450 frames without a gusset kit or rear subframe support brackets(next item after the new frame installed.fingers crossed).
