madzx2
I know that the 02 srx wiring harness will let a viper cdi plug in but can I use an 04 viper harness with a 02 srx cdi? I'm converting a 2000 srx to dcs and so far I have the 02 cdi but am curious if I can use a 02 srx harness or an 04 viper harness.
Woody255
Something tells me the 2000 stator plug is different than the 2002. I converted a 98 electrical system to a 2001, but I changed everything including the complete harness, CDI, stator, lighting coil, voltage regulator. Even the tach plugs are different.
I think the 2000 had a solitary electrical system. Different from the 98-99, and different again from the 2001,02.
Good luck.
Good luck.
madzx2
I'm pretty sure the stators are all the same 2000-2002. The cdi plugs are different I know that.
Woody255
They could be, I'm not 100% sure.
YAMMIEGOD3:16
stator are the same. 2000 srx has different plug hence takes its own cdi. 2001 and on is good to go 3:16x (yammie tony)
madzx2
So can I use an 04 viper harness with an 02 srx cdi and still have dcs work and everything else?
madzx2
Or maybe buy two used 01 or 02 viper harnesses and make one 02 srx harness
YAMMIEGOD3:16
yes on your first post. the 01 srx cdi will not have dcs feature. but will still plug in. 3:16x (yammie tony)
madzx2
I have a 2002 srx cdi. Will it work and dcs work on a 04 viper harness?
