Autolube Pump Rebuild
chadzeilenga
Crete, IL
Does anyone have experience with needing to rebuild 80's Autolube Pumps?
I have what appears to be a used one in good shape and am wondering if I need to do the gaskets/seals before I install on my 83 440?
My last experience rebuilding one didn't end up well, and I'm wondering if I should even bother?
Has anyone developed leaks from the seals/gaskets over time?
there is only one gasket for the pump itself when you mount it to the drive other than that there only other place they like to leak from it the tach drive ...bolt it on and go
