Cwagner100
Hi guys I'm installing the 7.5 SRX 440 wheels in my SRx 700 skid. Do I cut off an 1/8 inch off every spacer including the outer spacers on the rear axle?
Thanks!
Thanks!
Cwagner100
I found a write up from Mr Viper that said take an 1/8in off each spacer. Does that sound about right?
yes, 1/8 off all rear spacers if using aftermarket wheels as the bearings are wider and if you don't narrow the spacers when you go to put the last outside wheel on it will not be on the shoulder of the axle. (The bearings are narrower on the 2000 and newer wheels).
Cwagner100
Thank you!!
