Lil' Mtndreamer New member Joined Dec 5, 2015 Messages 135 Location Iowa Oct 22, 2016 #1 Hello everybody, I have a MM600, I pulled off the primary clutch and found a bunch of grease on the main bearing, it seems that the seal is bad. Should I Replace The Whole Bearing?
Maim Super Moderator Joined Mar 13, 2004 Messages 4,815 Age 50 Location sudbury on. canada Oct 23, 2016 #2 check it once you have it apart to replace seal. if bearing is rough, replace it and check them all while apart.
roudyroy1 Active member Joined Jan 10, 2013 Messages 1,517 Location ontario GTA Oct 24, 2016 #3 replace the seal, probably just went bad due to age. sometimes, bearing slop can take seals out so check it anyways.
