This is for the guys that have these remote adjusters for the fuel screws. Just how often do you honestly adjust them anyway? Are they worth putting on?
Sent from my XT1058 using Tapatalk
I don't adjust them very often. I fine tuned to get egt(s) closer together. After initial setup basically small adjustments every once in a while.
-worth putting on??? Tough call...are you constantly changing things on your sled? (Pipe set ups-clutching-airflow) I think they are kind of expensive but convenient. It gets old pulling your carb rack on and off just to adjust a quarter turn.
max17ime
I have a set I could sale. PM me if interested!
I don't change the setup on my sleds much at all throughout the season,with the exception of belt shimming as it wears.I never really gave much thought to putting a set on in the past because I rarely ever think of fiddling with the carbs out on a ride but I have the one ported sled and thought it might benefit from a tweak here and there.Max if I do decide to add a set I'll look you up.
