94 Phazer II motor swap
SJRTX
New Brunswick Canada
Two questions # 1 In the process of putting 91 Phazer II motor into 94 Phazer II will be a direct drop in bolt up, is wiring harness the same?
#2 putting 91 Phazer II motor into 86 Phazer what modifications will be needed ?
Thks
for the 94 you will have to swap stator and flywheel
91 to the 86 is direct bolt in the engines themselves are pretty much all the same form 84-97 just some ignition changes
