2000 Phazer 500 Torque Specs/?s/Manual?
ghostrider
I am assembling a 2000 phazer 500 fan from the crank up, does anyone have the torque specs for this motor or a manual available? Also what Gasket
maker to seal the cases looks like something very fine and not a lot was used from the factory.
Thanks!
case bolts are torqued to 18ft lbs cylinder nuts 18ftlbs head bolts 10 ftlbs case sealer to use is yamabond 4
