merc9193
On a 02 Viper. how do you change the fuel filter that is in the tank. I see the 2 bolts that are behind the air filter assembly. do I have to fish the filter out the fill cap on the top. if so how do I hook up the new filter to the pipe in the tank. Also I bought some nylon washers to put under the fuel pump so it isn't sitting directly against the belly pan. I read this is a fix for the fuel pump freezing.
super1c
Super Moderator
http://www.totallyamaha.net/forums/...rx-fuel-filter?highlight=changing+fuel+filter Never done it but use the search and you will find many posts on this. Here was the first one to come up. Search "changing fuel filter" They are all virtually the same processes.
