phazernut
I started out to change the RH trailing arm today. The previous owner had damaged it and repaired it. It looked like crap so I has to be changed. I bought and aftermarket Arm online and it looks great. When I tried to install the rear bushing it will not go in. The bushing appears to be too big. It is only marginally large. Is there a trick to getting these in? Or did i get a crappy part that wont work. I couldnt get the original bushing out of the Arm so I picked up a new one at the dealer.
Motodeficient
Try putting the bushing in the freezer for a while.
bluewho
I squeeze them in with a table vice and remove the old ones with a hacksaw cutting the metal around them.
A couple of bucks
And in conjunction, heat the arm up w/ a heat gun.Try putting the bushing in the freezer for a while.
phazernut
I have the bushing in the freezer for the night. will see what morning brings
phazernut
Still no luck. Had the bushing in the freezer all night and heated the arm with a heat gun and it will still not fit. I'm starting to the the aftermarket Trailing arm is crap.
A couple of bucks
Are you able to mount the bushing on a mandrel and chuck it up in a drill? Then sand down to a snug fit.
sgauthier
I had the same issue with the trailing arms i bought from Royal on my vmax 700 when i redid it years ago. i just ground/filed the outside of the new Yamaha bushing until i could just get it to sit approx 1/4" or so in the trailing arm removed it then I added some grease and pressed it in on my bench vise. worked for me
You save yourself a lot of money doing this way compared to the OEM part with the bushing installed. when i did ours the OEM was like $300 each with the bushing.
I paid a machine shop to do a similar project on Wifeys Polaris skid. New bushing couldnt be bought. They pressed out the old bushing, made a new bushing and pressed it in. $60.00. Fit even better than original.
