Headlight Wiring Harness Question
srxr700
Lifetime VIP Member
cedar springs, mi
I have the dual bulb assembly installed on my Vmax. I'm still running the old ignition system and plan on running dual 35w halogens to start... Is there a plug n play headlight harness that will work with the two connectors? Or do I need to splice a new connection into the stock harness?
You can buy the upper headlight harness from a dual bulb sled and plug and play, (it's the one wire running up the hood) or splice in another female socket to existing harness.
do you know what part number I need? I bought a 02 vmax harness and the connections are different at the good hinge.
