sledtillsed
I just restored my 80 Exciter and replaced all the rubber internals of the pump available. After running it a few times last winter oil is leaking badly around the speedo cable that screws into the oil pump
http://uploads.tapatalk-cdn.com/20161121/4f524742310ce7aba1aad041c59c7475.jpg[/IMG
I tightened the nut with pliers but don't want to break it
Anyone have a fix for this. Was there an o ring up inside the nut. Would a oil resistant silicone work ?
Any thoughts ?
Sent from my iPhone using Tapatalk[IMG]http://uploads.tapatalk-cdn.com/20161121/e35e034fbd11369abd8ddba0873ae577.jpg
Any thoughts ?
Throttle Junkie35
Replace the seal. Part no. 93104-06033-00
sledtillsed
I looked up the speedo gear parts break down and didn't see this seal ? Mine is leaking above the nut Between the top of the nut and speedo cable sheath.
Yamaha Nutz
what Throttle junkie said it needs the seal for the tach drive shaft 93104-06033-00
sledtillsed
Ok. Thanks guys for the info. Will dig into finding a couple seals
Cheers !
Cheers !
I have the same problem on my 93 Phazer ST, however do not see a seal on the pump assembly that would stop this leak?
Any suggestions?
Any suggestions?
Throttle Junkie35
Any suggestions?
http://shop.portyamaha.com/fiche_se...Snowmobiles&make=Yamaha&year=1980&fveh=175994 Item number 12 for the 80 Exciter
http://shop.portyamaha.com/fiche_se...Snowmobiles&make=Yamaha&year=1993&fveh=176138 Item 26 for the Phazer...same part number
Thanks TJ35!!!
Damn Embarrassing! I feel so dumb, I was looking at the oil pump schematic..... Cheers!
vmax-540
Also check to make sure the shaft and /or bushing under the seal is not wore, you may need to replace all three, hopefully not but you better check it out..
sledtillsed
For sure. Thought about a worn shaft, as I am pretty sure I replaced that seal last year during the resto. Will pull it all apart again
