nick5oh
I know it's a 17.2 and a 13.3....thinking it's the 4.5 gram and 3.1 gram versions....but not absolutely positive. Couldn't get the info needed using partzilla. Looking to clarify what rivets are stock for the 8DN-10 weights and where they are inserted into the weight?
4.5 gram inner and 3.1 gram outer?
Want to get the stuff ordered so I can get my clutch sorted out. Going all stock to make sure sled is good, then I'll start playing with helix's.
One other thing is, what is the preferred/best method to install the rivets? I assume they slide through the weight and then you have to smack em with a pointy punch to mushroom them or crush em with a vise?
Let's hear the methods.
Thanks guys!
Thanks guys!
Nuts and bolts work well for testing. You can still order them from bender or maybe it was Hauck. Little lock tight once you have your weights set good to go.
99 srx would have come stock with 8dn10 set up with 13.3 inner and 17.2 in tip, should have a yellow/white/yellow spring. 15mm rollers.
nick5oh
17.2 4.5 gram and 13.3 3.1 grams? There's a few 13.3's?
nick5oh
Here's a funny thing. Yammy dealer tells me only the 13.3 on the inner hole is what the sled comes with stock? Interesting????????!
drew24
http://www.totallyamaha.com/snowmobiles/aaTECH/drivespecs/Rivets_Rollers.htm
You want the 3.1 gram 13.3 and the 4.5 gram 17.2
