Looking for guidance on how to correctly remove the bearings from the fan case. I see there is a circlip/snap ring and washer between the two bearings in the parts diagram...not on the outside of the bearing. View attachment 61960![]()
You should be able to see if it has a clip holding it in. I would support it good on one side and just start tapping and see if you can get it to move.
