99 SRX primary parts? Is my junk correct?
nick5oh
Hunstville, Ontario
Primary fixed sheave stamped 8CR00
Primary sliding sheave stamped 8BV01
Spider stamped 8BW
Primary sheave cap stamped 8DF00
Correct part number for spider starts with 8CA but my sled is 8BW?
Reason I'm asking this stuff is cause I want my parts correct, I want to buy a used primary, that is correct for my sled, but don't know if mine is correct so I can compare.
My primary has play, the sheaves are cracked near the shaft, and they appear mushroomed a bit near the shaft as well. Mechanic at the dealer told me pressing out the bushings would be fine, and getting new ones in would work probably, but because it appears mushroomed the sheaves may not slide properly which defeats the purpose of new bushings.
i believe your correct. after 1997 i think the spiders were changed to the small set screws for the rollers. look this is cracked so just find another primary. 3;16x (yammie tony)
