Please see the attached picture.
This is my sons field bomber and unfortunately the forward skid mount cross shaft seized and slowly stretched the mounting holes. The opposite has been repaired by the previous owner by welding a flat washer over the hole, but I have no way of knowing if it's the original location or not. Do any of you have this sled and can forward a picture or dimensions to locate the hole? I included some reference dimensions on a few of the rivets.
sifton
Had the same on one of mine. I drilled out rivets and made a plate for the outer and drilled hole. I would say the lower of the oblonged hole is where you should be. Put back the inner also.
