Cumminsguy
I recently got my first modern sled. It is an 01 sxr 700. I serviced it to get ready for the first rideable snow of the season. The track is worn but I think I can get this season out of it. I was wondering what to purchase for a replacement track. I would probably only ride groomed trails a Couple times a year. The rest would be spent near home riding local non-groomed trails. Thank you for any info you could give me.
Vincent
Alot of members including myself have had great luck with the Cobra track. It's does a great job on or off trails.
If your budget permits longer tracks like 136 to 144s make a significant difference to.
After riding with your worn out short track for awhile you'll welcome and appreciate the upgrade!
If your going to run studs then I'd say a 1" Camoplast Carve or Hacksaw,but if not then go with a 1 1/4 Ripsaw II or a Cobra like what Vincent said.Snow conditions really will play into your final decision.Some tracks are better in hard packed trails and some shine in loose snow.
Master_o_69
camoplast predator
A couple of bucks
What are your conditions. Gravel roads, lots of road crossings, corn stubble, woodsy, drifts, ditches etc etc.
Cumminsguy
Mostly woods trails, farm fields, powerlines, a little bit of road shoulders. Then maybe some groomed trails up in the tughill old forge area a couple times a year.
A couple of bucks
A 1.5 Intense sounds like it would fit your needs well.
https://camso.co/en/products-solutions/snowmobile/products/intense?ridingSegment=1&p=PS17
Motodeficient
From what I've read on the viper, 1.25" without studs is about the max you can go without removing the tunnel protectors and heat exchanger cover. I imagine it's a similar situation on the SRX? My viper has the original finger track and I've been looking at the cobra, predator and intense tracks also.
Cumminsguy
It's been a while guys. Took a trip to old forge this past weekend. Before going I had thoroughly cleaned the carbs. Did reed notch and silencer mod. Sled ran awesome. Rode with 4 friends with picks. They got me on the lake on the start. I got them on the big end though. They rode mxz 800's and a gsx 600 or something. The old red head 700 triple made its presence known. I was to happy at the end.
A couple of bucks
16 Y/O sled getting her done!!!
