Need info for rebuild kit for mikuni carb off a 83' 300 enticer
Only thing I can help you with would be to google 'yamahapartsnation.com' or type it into the address box at top of screen. From there you can look up snowmobile parts back to 1968 which coincide with the OEM yamaha parts numbers. Of which due to the age I think you should replace springs, needle valve assembly (doesnt have the needle seat seperate so I am assuming it comes in the assembly), carb gasket, and o-rings.
