96 Vmax What to do with my heat exchanger?
Carbon Fibr
Alliston
So I went for a rip today. All was good until i punched a hole in my rear heat exchanger.
I extended the track from 121 to 136. And the stock 121 tunnel had this Radiator that curved down. I figured Id leave it (stupid); thinking that the suspension wouldn't compress enough to smoke it. Sure enough it did.
What have others done or what should i do?
Should i buy a stock replacement and just try and move it back and extend the rad hoses or find a flat heat exchanger?
Any input greatly appreciated.
(pic of it hit by studs and bent forward)
most guys move it back to the end of the tunnel extention and extend the hoses from the tunnel coolers, or they cut them in half, lay it out flat and re weld them together.
Ok cool thanks. I think im going to go with cutting off that extra that hangs down and weld it up.
Thanks again fellow's.
You could make a crossover pipe out of copper pipe and put it in the tunnel. It all depends on if your just going to ride deep snow or not. You should have more than sufficient cooling if it's not going to be on the trails any more.
