sx70097
Hello guys new to the forum, i have a 97 yamaha vmax 700 triple what i need is all the ohm readings for the stator and what pins to probe to get the readings, i lost spark, replaced cdi and coils still nothing, i just need the spec ranges for the ohms and where to pin it out any help is very appreciated
super1c
Super Moderator
http://www.totallyamaha.net/forums/...x-700SX-stator-specs?highlight=Testing+stator. Use the search feature at top right. Tons of good info for this. Welcome to the site!
super1c
Super Moderator
sx70097
Thank you very much exactly what I needed
sx70097
Okay guys just ohmed out everything got 194 ohms on pick up coil thats w/r and w/g wires, 420 ohms on b/r and brown wire, and nothing on brown and brown/red wire so safe to say stator is bad?
sx70097
Pulled the stator out was really easy!!! Had it out in 10 min, tried ohming it again and only thing that was reading was the trigger coil everything else across the board read nothing, except lighting coils they still worked
