question on offset axles
ejcamaro
Life Member
Wonewoc, Wisconsin
Website
www.myspace.com
Anyone know what the best kit is for going to 8 inch wheels for an SRX? High Performance Engineering sells a kit, but it only changes the outside wheels to 8 inch, the inside 2 are stock sized. Doesn't this defeat the purpose of going to bigger wheels if the inside 2 don't change? Any info is greatly appreciated.
its a miss print at high performance engineering,I purchased that kit for my srx and it uses all 8 inch wheels.-Harvey
another option over offset axle.......
or you can just run 7.50" wheels on the stock axle, and then run 5.350" on the other 6 wheels, works great and saves some $$, the wheels you want are from a 78-9 srx440, or 78-79 exciter 440, they make them in plastic or aluminum, they will bolt right on same 20mm axle.
