looking for some info
HDYAMAHA84
north central Ohio
I'm looking to update my 02 viper for a newer one. found a 05 long track, nice clean sled BUT the temp and warning light always flashes? what code is it throwing? any input would appreciated! thanks
Need more info. Is there a pause in the flashes and then start the sequence again? Like flash flash flash pause, flash pause flash flash. Fast flash slow flash. Look for mice chew under bar pad, wire rub through. Possible short. Low on fuel?
If the warning light is flashing 8x then a 3 second pause and repeating, my manual is saying the thermocouple is either disconnected or there's a short circuit.
Could be mice or rub thru.
Im not sure about the sequence or how many times? its for sale on the internet. the ad says its runs great no issues except for the flashing. if its a wiring problem than it could be a nightmare it sounds like
