Johnnybravo300
I need trailing arms, probably both sides. It has fabcraft now and they are pretty shredded and flimsy.
Im not sure which model I have of viper. I know it's an 03 but that's all I have so far. I just picked this up recently. It has a center grab strap, a long track (160 maybe?), says "deep snow special" along the windshield.
I don't think the correct t arms were put on last time. Should this have the wider stance? It's at about 38 inches now but it doesn't look like things are lining up right.
The vin is jye8en0043a00182 if that helps. The dealer in Gunnison gave me a price of 120 but he couldn't tell me which model it was? I just want to make sure it's the right part. Thanks!
staggs65
Sounds like a mountain Viper. Mt Viper would have no sway bar and 8 tooth drivers. They also have the narrower front so different trailing arms and shocks. I think I actually have a set of Mt Viper trailing arms and spindles kicking around.
Johnnybravo300
I don't see any sway bar under there. I don't see any markings on the t arms to indicate either way.
I'm not exactly sure where to measure the stance. Neither t arm is straight so the measurements widen out at the top. Measuring may not be the way to do this.
This is my fifth sled in the last few years and this always happens. When the stickers fall off all sled info is lost. What a pain. Not as easy as a dirt bike that's for sure.
staggs65
Search member snowdad4 he knows the Mt sleds really well and can probably figure it out for you really quick
staggs65
http://www.totallyamaha.net/forums/member.php/779-snowdad4
Try sending him a message. He hasn't been on since October though
Johnnybravo300
From what I can tell I need the m stamped t arms. Those are the viper ones I guess.
If you have a set youd want to sell I'd be interested. I just had shoulder surgery so im not in a huge hurry. I have a month in this sling so I'm just trying to get parts lined out. I doubt if my wife will wrench for me haha
Maybe she knows what trailing arms you need...lol
Johnnybravo300
You need "N" trailing arms for a mtn viper. The trail vipers used "M" arms.
Sent from my SM-G920R4 using Tapatalk
Well do I have a viper or Mtn viper? What's the difference?
Johnnybravo300
Ok that sounds like mine for sure. Thanks!
VIN "8EN" is Mtn, and VIN "8EK" is Std. But parts can be easily swapped to convert.
