3g racing
2001 srx 700 how many miles are they good for realistically is 12000 to many on stock cylinders ?
not if the rings have been changed to keep the piston from getting sloppy and rubbing the skirts on the cylinders. The nicasil is very,very hard and wears like iron.
3g racing
Thanks don.. might picking one up for a good price with 12000 miles on it from the original owner might need your helpnot if the rings have been changed to keep the piston from getting sloppy and rubbing the skirts on the cylinders. The nicasil is very,very hard and wears like iron.
SWEDE
My sx 700r has nearly 17000 miles on original cylinders and still runs great! I think I've reringed it three times over the years. It's finally getting swapped out for a low mileage ported engine due to the mag side crank seal coming apart
Sent from my SAMSUNG-SM-J120A using Tapatalk
I think these machines whether an srx or a viper, if maintained well by the owner are extremely reliable. When buying anything used today, I look at the owner almost more then I look at the machine.
I bought a quad, and when the owner said he didn't know if it was carbonated or fi, I said "sold" because I knew he had never modified anything.
staggs65
That's the truth of it right there. I've bought em with 5000 miles that the whole sled is ready for scrap and 10,000 miles that look like new
Hammer Down
12,500 on mine. Never been apart as far as I can tell. Has even 125 on each cylinder.
My black srx chassis has 25.0000 miles on it and on my second crank .they will last if u do maintence
chiefsledhead
Mine has 18000 miles on it. The only thing that caught me off guard was the metal cage around the reed valves. One of them broke and sucked into the cylinder. When I pulled the other ones out, three of the remaining five were cracked and ready to go. Once you hit 15000 miles, pull the reeds and look very closely at the metal cage!!!!
Shredder
I just bought one with 10k miles. Still had good compression. All 120 psi when i checked it. Im assuming the motor has never been done. Did pull my power valves to clean yesterday and the cables were pulled through of them tho.
