3 washers on secondary clutch. im confused 2000 srx 700
newbie
United States
just changed my track out and im putting back together . putting the secondary clutch on and i noticed on parts diagram there are 3 washers. number 28 on parts diagram. i did not have them when i took it off. do i need them? i noticed on the sxr they do not use them on the diagram. the 3 washers look like they go between clutch and bearing on the jack shaft. do they space the clutch out? i tightened clutch on but seems like a quarter in of play on the clutch moving back and forth and i dont want to over tighten bolt that holds clutch on. ty for your time and help
how do i measure the offset? sorry probally a dumb question . sled has 1200 miles on it so it is as almost like is rolled off assembly line . so i guess my question is . were those washers stock when it was built? if so im just gonna order and put them on. i just dont recall taking them off. and when you tighten the bolt that holds the clutch to the jack shaft how far should i turn it on?
Those washers take up the extra play in the self aligning secondary. If you can i would eventually get some as they did come on stock but you can run without out it.
