Stock srx jetting
Hammer Down
Flint
Just curious why the stock pilots are only 40 on the srx700 01. Seems lean to me. But then again, my sled runs great for over 10,000 miles. I did bump the fuel screws to 1-3/4 though. 150/147.5/147.5
Anyone have the part number for the rubber o-ring on the needle seat under the float.? Mine aren't brittle but two don't seem to seal as tight as the third
Anyone have the part number for the rubber o-ring on the needle seat under the float.? Mine aren't brittle but two don't seem to seal as tight as the third[/QUOTE
If you want to save some money you can buy those o rings just about anywhere, I got a 50 pack on ebay for around $6, the size is
7mm id 1.5mm thick
Any opinions on the 40 pilots for trail riding. It can get pretty cold in the UP. I did bump the screws from stock 1-1/8 to 1-3/4. The motor has lived for a long time with stock jetting but it's no biggie to change them out.
