Simmons gen 1 ski carbide opinions
03viperguy
Alton, NH
with the viper finally back on the snow its time to get a few things in order. first thing being that I'm due for some carbides. anyone have opinions or experiences? shaper bars? bergstrom triple points are just too spendy for me, so those are out. woodys? thanks guys!
I've had good luck with the snow stud brand and their priced right. Maybe check ebay
Sent from my SAMSUNG-SM-J120A using Tapatalk
Make sure your ski stoppers are shimmed on the back too. Very important on Simmons
Do you run two 4" carbide in each ski? Or a 4" or 8" on the outside and shaper bar on the inside.? I've got a set of these on my srx and am wondering what carbides combo you guys are running.
6" works great even with my 136" track. The inside carbides do most of the turning with the way the skis tilt. I've just replaced the inside runners and swap the best used ones to the outside
Thanks. I'm sure 4" will be fine for a 121". I Assumed the outer carbide would do more so that's good to know. What do you shim the skis with? (Thickness, material etc. )
I used a chunk of old belt as a shim. Cut the ribs off it, worked perfect
Sent from my XT1254 using Tapatalk
