90's Phazer gas tank and oil resevoir breather tube routing
NorthofSixty
Yellowknife, NWT
Working on a Phazer last night with fuel problems. Would run for perfect several minutes and then starve itself of fuel and shut down. I found the breather hoses for both the gas tank and oil reservoir had been looped up inside the steering column just below the spedo/tach and back down. I rerouted them back according to the original routing which has fixed the problem. I suspect the vent hose was plugged or pinched.
Does anyone know if there was a tech update for the early 90's Phazers for rerouting the breather hoses?
