02 viper oil consumption
It depends on how it is ridden. The rule of thumb is about a quart per tank but it can vary a bit. A lot of wide open will go through more than trail riding at half throttle a lot.
Thanks drew24. Typically I would expect to get easily two tanks of gas thru without even worrying about the oil if it was full to start with. The last tank used about 600-700 ml, so I guess I am on the right pace.
