2000ws6transam
Sleds been tore apart for a few weeks and the kids decided to toss all the bolts shims spacers exc.. I had laid out into a big pile.Have the case back on just confused a bit on the gears and spacers and no idea on the parking brake. any pics would be helpful or how the spacing should be. it looks as if top has a thick or thin spacer then gear then another spacer and then the nut? and torque specs? Thanks for any help!
big spacer goes on top shaft, little spacer goes on bottom shaft.
then the top gear then thin washer, then nut.
bottom gear, washer and bolt.
you shouldn't have any other spacers, if you have the case back on there is spacers that fit into the backside of chaincase. if you post pics I can help you to see what all you have left over.
2000ws6transam
that should have me rolling, yes I seen the ones with the rubber o ring on the back of the case. figured the only place they would do something.
