2000 srx lowend bog
chascook
vt
hi guys its been awhile i just bought a 2000 srx i have a 98 but the new one has a terrible lowend bog carbs have been out 3 times power valves where upside down they are right now gas waas drained and new in when it comes out of the bog it goes like hell and hell or direction would be great i will tell you everything its doing hi idle when you start it with choke it will takeoff 4 to 5 grand and then the lowend bog so again any help would be great thanks for and help
ps make sure when you buy a sled off someone that should be working on them go through it with a fine tooth comb
Pilot screw 1.5 to 1.75 turns out? Choke set properly? Carb boots? Hard to start?
its not hard to start ill check pilot screws and boots they seemed fine and i was thinking clutches where dirty
