Carb settings for stock 99 SRX? Want to make sure I'm ok?
nick5oh
Hunstville, Ontario
Well.....I finally got my sled sorted out. :)
thanks to ty forum members for all the help last season and up til now. had serious issues with sled not accelerating like it should. Turned out to be something REAL REAL stupid but I got it sorted out lol!
Anyways....now that the sled is making jam id like to know that it is safe with carb settings etc so I don't burn er down.
Sled is stock, 99 model SRX, I have the idle set at stock 1800ish rpm, fuel screws set to stock (what it says on the belt guard 1&1/8 turns out), the throttle free play at 1-2mm, oil cable set at 20mm which I've read here is on the rich side of spec (20-22mm), I hope 20mm is rich on oil not lean???? I noticed that the sled does burn more oil now with this setting than it did last year. Just to note all jettting, pilots mains needles etc is all stock. I've read vipers need needle changes to live, wondering about srx's as far as stock settings being good or not? Not worried about the typical idle hang or "high stock setting idle rpm", unless it is an issue.
Thanks in advance guys!
