viper control Arms on SRX?
Big Doaba
Carleton Place
Looking to Put upper and lower arms off a Viper onto my srx as well as the steering arms. I have viper shocks as well i want to put on. wondering if everything should bolt on to my existing srx trailing arms?
If I remember correctly the control rods for the viper and srx are the same length and the holes in the bulkhead are farther apart on the viper and that's why its wider. The viper shocks mount differently on the top. Have to make a different bracket to mount them. I think the venture and a couple other models had the longer control rods. I looked into this once but its been a while. Do some searching and you should be able to find out what you need to do.
I just checked the manuals and the rods are a little longer on the viper. Top rod on srx is 18.12" and the bottom is 18.06". The top on the viper is 18.4882" and the bottom is 18.3622". Not sure what I was remembering. There are good posts somewhere on this site that would let you know for sure what to do. betheviper is a good guy to ask but I haven't seen him on here in a while.
