drew24
I'm working on a couple 02 vmax's for a friend. One of them is leaking antifreeze from the water pump. I have the parts here to do one on a srx and all the part numbers for the seals are the same except for the seal washer that goes on the bolt for the impeller. Does anyone know what the difference would be? The impeller is the same part number between the two so not sure why it would be different. I have not tore into it yet. Just thought if I could use my parts and reorder them later it would be easier. Thanks, Drew
Update: seal washers are the same. Still showed the old number for the srx on the site where I purchased it.
