So backing it into the barn this morning my left ski caught something and turned 90 degrees to the left. Right ski followed but didn't go 90. Put it in drive and went slow around the yard. Didn't seem to have an issue. Left steering bar bent a little. Should I be concerned?
sleddineinar
Set the skis straight and measure the distance between the rear of the skis center to center then do the same with the ski loops, see what the difference is. About 1/8" toe-out is what you want. Toe-in is not desirable.
