Hello, just looking for suggestions on my 98 srx.
I just installed adjustable transfer rods and I am quite happy with the results. The only thing I noticed was my left ski seems to lift more than the right. What would be the best/easiest way to even it out. Thanks in advance
pete_man26
Check for broken limiter straps, then use a tape measure or caliper to measure the transfer rod length to make sure they are even. Should be good to go. Oh and stop leaning to the right. JK
Check engine mounts,, will torque belt on clutches and lift One side up higher.................
Stop going around in circles LOL - Seriously though, check for bent parts that may be binding. If you can't find it easily, just go through both suspensions including the springs and shocks.
hessracing
do you have a worn out ski bumper letting one side tip down ?
