Speed Run suspension set up
justin1620
ON, Canada
Would I run into any problems like track rubbing if I removed both rear springs from both rear shocks to get sled lower and save a bit of weight? The rear springs are heavy....this would be for ice speed runs.....thanks
for the pound that you might save, why even mess with it? loosen shocks to get it to compress tie down if you want, unless this is going to be an attempt at a record dont waste your time not to mention this can not be done period :-l
umm with no springs there is nothing to hold it up will just collapse to the shocks bottom out.....................no, it wont work
