Have a broken power valve bolt in cylinder. Going to remove cylinder & don't want to dump coolant in crank case. Is there drain low on the case ? Are there any tricks to getting air out of cooling system
ya, on top of the waterpump cover there is a silver headed (10mm socket) bolt, says drain next to it. its the only silver colored one and has a copper sealing washer, remove that bolt and it will drain the topend.
you can catch coolant with zip lock bags to eliminate mess or if you plan on reusing
Racenut13
A couple of bucks
Another GREAT idea! I'm stealing that one!
A couple of bucks
Works on vehicles too. Just need to remove the thermostat and stuff a golf ball tee in the overflow tube.
super1c
Super Moderator
I always just unhook rear coolant hose and suck out with shop vac. Coolants cheap and needs a good refresh now and then. Just use safe for aluminum block, silica free. 50/50 is fine but I use 60/40 Yamaha specs.
