Vmax4 bar riser
If the bolt pattern is the same, you might be able to add, or stack, the lower clamp part(s) from the vmax twins, then measure for longer bolts from an industrial supply or hardware store. Might have to take measurements, get parts, and see how the setup looks. Back then, we always added the common +/- 1" spacer, with no cable problems, on the vmax twin sleds, and I think the V4's as well.
