2004yamahaviper
Hey I have a 2000 venture and had my end come off my old grip. I ordered apex style grip heaters with new grips. I put some 45 bar ends on and then the grips. Everything looks good but I am getting very little heat out of the grips. Thumb warmer is smoking hot. I have a bigger bulb in the headlight led tail light and am not using the passenger grips anymore. The old grips were hot.
		super1c
Super Moderator
The old venture grips and apex grips dont ohm out the same.   This is why the apex grips are colder then your venture grips were.   I dont remember the numbers off memory but there is quite a difference.   To make them work wire them in parallel instead of in a series.   So take one wire from each grip and wire into one wire from sled.  Then the other two wires from grips to other wire on sled.   This is wiring grips in parallel.    Here is a post to explain this.   Very good info.  http://www.totallyamaha.net/forums/showthread.php/78800-Viper-with-Apex-Bars
			2004yamahaviper
Thanks alot will try this asap
			2004yamahaviper
Well ran them in parallel last night works mint thanks alot
