Can i put a skid and track out of a max DX in my 600 xt proaction
Or are there any skids that almost bolt in with longer track and upgraded suspension
I dont cate for the proaction at all
I have many thing to do this off season
I need to make sur i can get the power to the ground and not just spin the track like it does now
Also would like to knowif i can lift the front pogo shocks up a extra 2or 3 inches
Ihave seen threds with others lifted front and rear up to4 inches but i think it to high.
What polaris or othe make skids will bolt in
With minimum fabrication that give better ride handling and height?
Im new to this so pleasebe patient
I truly appreciate all ther help so far
I
I
I have already purchased a 95 head gasket
Gyt twin pipes with jets
I have ordered a new chaincase a 20 tooth and 19 tooth top gear ang chains
Am i missing anything that is simple and basic?
Also have a comet clutch and will be buying a rebuild kit for both secondary and primary
A couple of bucks
Other than normal wear items (i.e..skid bearings) you should be golden. Put extra $ in rebuilding shocks or some better skis.I have already purchased a 95 head gasket
